OK, I changed the stator, Pump bushing and seals, O rings and the washers. It still leaks. It is wet behind the torque converter clear to the top. I looked by using a camera and saw that it is all wet but that the vent is dry. Will the dye even work in this case? What dye is this and where can I get it?. Any other ideas?
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
