The other thing is that I don't think a low rpm pump gas engine is all that good of a test bed for this stuff. If I really want to see what is going on I need to build a high rpm screamer and then do some testing. Probably need to build something that has a power peak up around 8000 or 8500 rpm before the power changes start to get bigger. Just not a lot of choices for doing that with a BB Mopar unless I buy a KB block and then get some B1 heads or something like that.
you could build a steel crank high rpm 400. that is if we had money to burn
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
