The dyno test was very misleading, who would use a very modified intake on the smaller heads and use a unmodified intake on the bigger heads, with no dyno sheet to see were they make HP and TQ. How much crankcase vac ? Peak RPM etc. fast68plymouth is right on with is post. Its great to test things, but more info would be nice. Did you move the cam ?
