I realize this has yet to be tested, but for a RB block and the 270 head, what would the preferred intake be? I am running a 4150 now, so I would likely run an adapter on the Dommy intakes
Super Victor, port-matched TF, 440-3?
There are lots of choices for RB intakes with MW ports. For a race engine I'd probably start with the Super Victor but the Mopar 337 is also a very good intake. People have had good luck with the 440-2 over the years. Then there are the multi-carb intakes such as the cross ram, Indy X ram and Mod Man. There is even the Indy DP which is available with MW ports. I wouldn't run the dual plane on a race engine but it works nice on a street engine.
