I spent some more time with the data and looked at avg power and area under the curve. For dry sump vs. wet sump + vac pump the avg hp was 634 vs. 635. So the wet sump + vac pump was 0.2% better. Very small difference. Area under the curve was similar results. Wet sump with vac pump was 19710 vs. 19644 so 0.3% better. So I think that is a tie.
The biggest difference was the Wilson porting. 639 avg hp vs. 624 avg hp for unported. Area under the curve was 19819 ported vs. 19355 unported. Right at a 2.5% power increase in both avg and area under curve. Pretty significant increase.
The pulls were 4000 to 7000 so avg power is from 4000 to 7000. 630 hp average from 4000 to 7000 seems pretty good to me.
