Along with the previously mentioned items, the underhood cowl needs blackout, remove that tag on the battery, that tag was never supplied nor correct, voltage regulator "should" be white lettered IMHO, that plastic zip tie on the heater hoses has to go, there's an aluminum strap tie for that...
Checkvalve on booster should be painted black as well (the entire booster/master assy was delivered to the line as a black painted assy), valve cover breather hose missing clips...remove the grommet from the headlight floor dimmer switch, factory just cut a slice for the dimmer, no grommet ever...You'll need correct HEMI battery cables/terminal ends, that's a difficult find though...the ralley dash woodgrain appears to be of 71 (Kasmir walnut) vintage, IMHO I'd change it out for the lighter American Walnut grain used on 70- to early/mid 71 E bodies. the darker reddish Kasmir grain was used mid 71- to 74 production...
IMHO the emission tag should be further back on the slanted portion of the sidewall, and it appears you need to change out one of the fender tag screws, as well as the aircleaner/filter element if correctness is your goal...
Nice car though! just a few small items that are easily rectified
