Check the clutch adjustment, if you can have someone use a feeler to stick in between the clutch disc and flywheel or pressue plate with the pedal depressed like you drive it see how much air gap you get and let us know Mopars are famous for dragging clutch disc Which makes them hard to shift and put into gear Good luck, you CAN fix it
