I pulled the Spectra CR9CFI pump out and it is a Walbro (USA) Part number GSS342, 255 lph pump.
Reference:
http://walbrofuelpumps.com/255lph-walbro-gss342-intank-fuel-pump.htmlI bought a Walbro TIA485-2 pump, 450 LPH that will run E-85 and I was going to run it in place of the GSS342 pump, but I would have had to modify the bracket holding the pump, and just decided to use the GSS342 pump for the time being as I have not gotten the new ECU and flex-fuel sensor wired in.
The CR9CFI with the GSS342 seemed to perform just fine with the old Edelbrock XT EFI system, but I'm probably under 500 HP at this altitude.
