interesting reading from the DC book. I have the book but never advertised that... will search and read
I scanned through the posts in the thread and didn't notice anyone mentioning the fact that the 69 335hp 383 motor had positive deck height flat top pistons originally.
If you mention that, somebody will insist that they weren't +dh, so I never say anything.
How much + have you measured them?
Long ago, far far away. It was less than .100 , if my yellow book surfaces I will check to see if it mentions it.
less than .100"??? still being .050 sounds a bit of too much for a factory assembly!!! I have had constanty bad decking jobs on my 400 and I'm worried now will have to cut it again and hoping will be getting around 0.020. on one of the sides. The other side seems to be at zero. Will use the felpro brass shim on that side to get both sides equalized.
well that was a bit off topic.
