I know the Superbee/RR 383 HP got a diff camshaft than the 383 HP Magnum/supercomando used on the Charger, Coronet, Satellite and as far I know is the only difference, but what are the spec on them?
Is the lower of the purpleshaft cams correct for the 330 or to the 335 hp engine?
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
