On the air cleaner, air comes in from the bottom edge, the cover is a larger diameter than the base.
Gotcha, just detailing some dissasembled cleaners at nicksgarage website and can note now you mention the base is just about the filter element diameter due the recession shape I seeing, and the top supports over the element not over the base, then get an extra room after the support area for it.
Originally Posted By cudaman1969
No cast cranks till the 400.
Pretty sure on 70 and 71 383 2 bbls got cast
Non HP in 71 but forged in 70.
Humm. I do have a 71 fury in the back with the 383-2 bbl. I'll that check out. Factory service manuals are pretty thorough.
