[quote=rowin4]Ok, your ARP studs are special to use a girdle. My girdle use's ARP studs with the hex key insert. Did you read what you wrote about the lube between the caps? It doesn't make any sense. It sounds like you took what you wanted to hear from a lot of different answers . Good luck on your build your gonna need it quote]
I don't recall asking for any opinions. It's too bad you don't understand the information I provided. If you would like I can hook you up with the engineer who explained the lube vs dry deal. Perhaps he can bring it down a few notches so even you could understand...
You are very fortunate to have the hex in your ARP studs. Mine did not come that way from Hughes Engines. Maybe you could call Dave Hughes on my behalf and let him know how unfair it is that you have a hex in your studs and I don't..
Keep em coming, I love it!!!!!!!!!
