Crank installed!!!!! I made a few mods to the SDC caps to make installation easy. A bevel was milled into the edge of the cap for easier install and less galling on the cap into the block registers. I also removed material from the inside of the washer countersink on the caps so the socket fits onto the nuts without the caps material interfering. Lastly I drilled out the #3 cap to 17/32 for easier thrust adjustment. I also brushed moly onto the cap edges and block registers to help prevent galling.
Crank is in!
