nice build. I've heard both theories on the lubrication. personally I put mine in dry, and if you install the main studs first you can use them as a guide to slide the caps down and tap them into place. some guys like the bevels some don't. whatever you do, make your mods before the shop line bores it. its also good to simulate the install when line boring so that you and your shop do the exact same things.
keep us posted on the progress!!!!!
Superior Design Concepts 2574 Elliott Dr Troy MI 48083 jerry@sdconcepts.com www.sdconcepts.com Facebook page: Superior Design Concepts www.bcrproducts.com
