What made you decide the Borgeson was the better option?
Cost is close to the Firm Feel after you ship it across the World twice. Firm Feel is building on a 40 year old box, I feel that the Borgeson will have some inherent design improvements, weight reduction and better ratio.
The Borgeson requires that expensive adapter if you are using a stock column, I think I will be mitigating some of that cost and putting it into retrofitting a steering quickener...for even faster steering.
