Grease or bread(cleaner) works fine.
Here are some 2 and 3 finger internal and external pullers that would probably work.
But they are not the best way, I have a blind hole pullers that is made for specific range of bushings that goes on that big slide hammer. It is 2 pieces and you slide it into the blind hole and screw it together and it expands and a lip locks into behind the bushing and then you use a slide hammer.
Not sure if I have a picture of it? I will keep looking.
Mean while I would use grease or bread if I was you.
