so should i just go with the magnum intake?im guessing thats best.it even kinda makes sense!
Its the 100% no trouble way to go. you even buy the stock Mopar bolts like you had a pickup with a magnum engine and torque them to 12 ft/lbs. The magnum intake bolts are torque to yield, so only use them once.
