Originally Posted By Cab_Burge
Originally Posted By HP2
Originally Posted By gregsdart
Have you thought about doing some porting work on your own? If you ask on here, info on what to do for starters to get about 50 to 75 percent of possible flow gains can be done by the average guy taking his time. You could start by working with the valves you have, or upgrading the intakes to 2.14 size. Just doing the intakes will keep the cost down, and I am betting on good gains, even leaving the exhausts stock. Some of the other posters here can maybe chime in on that last suggestion.
I have been thinking of doing some porting myself, I actually like that kind of work and have done a lot of 2-stroke porting, but the problem is lack of time... and iron heads will need long hours frown
The valves are 2.14/1.81s
Weight loss is another reason I've been looking at alu.
Sell the iron heads and apply that money towards a better set of new aluminum heads twocents Buy the best you can afford at the time of purchase up
I think that's what I wanna do thumbs
but I'm still curious what you guys think what it will do in hp and ET's rolleyes
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
