If you shut if off really fast no metal would reach the oil filter yet , as the others mentioned , bent push rod and or broken rocker arm and if you prime the oil pump and it does not have any resistance (make sure your spinning the pump in the right direction) you might have sheared the oil pump drive shaft , good luck.
