Well I ordered it all last night - including the fast ratio pitman and idler arms.
I managed to get pretty decent deals.
Now I am in need of a master cylinder for my Wilwood setup:
www.summitracing.com/parts/wil-140-11020/overview/year/1969/make/plymouth/model/satelliteIt is the older Dynalite caliper with the Solid surface rotor.
I bought them for a great deal from a member here, and I want to install them while I'm doing the suspension work.
Any advice for what to use for a master cylinder - particularly size?
Thoughts on whether I should go power brakes at the same time?
I'm going to keep the stock 9'' drums on the back for now - eventually they'll get swapped for 11'' drums when I convert to an 8 3/4.
