Quote: Why? I went 9.55@140 with a 422 small block that I had 10k in. I went 9.90 with a stock block and 360-1 Indy heads. I had 8500 in that motor.
See, you spent alot more than I did. And it needed more RPM, and more octane. I made the last 2 up, only guessing. Some of you guys have above average small blocks, it's not the norm to run that quick with a fairly low dollar small block. You really know what you're doing. Running 9's with a cheap mild big block was easy for me and I had a ton of fun doing it. Still want to do a stroker SB soon though.
