I'm a big block guy, all day long. But, my 62 Valiant doesn't lend itself to a BBM installation easily, so I was forced to build a 428 small block street engine 615HP, 540 TQ, and a 10.49 best without much tuning so far.
I've had plenty of 440s, built cheaper, that ran about the same NA.
The difference is, I can put two kits on the 440 and run 8's. Not gonna get there with the small block!!!!
Why not ? Mine went 5.60 w a 150 tune,that's 8.80s.I shift at 7000 and it's w 20yr old indy heads.A stock 340 block IMO is also ALOT stronger then 440 blocks as they have a tendency to blow near the pan rail or split from what I've seen of the 3 blown 440 blocks in low hp mopars. A 400 block and B1s would be a good one I think,but NOT a 440 block.
Why not? Because I'm frightened to hit the small block with that much hose! I have a Big shot plate on it now, and it went 10.18, sawing through the 904 or convertor (likely both) shift light was on from the hit until I let off the n20 at 1100 ft. It's a 4 bolt main X block.
I split two cylinders in my 440 block on spray, sleeved it, and sprayed it some more, it had a high fill of block hardener in it.
The thing is...that 440 was a 2K$ short block, so I was more inclined to lean on it than this small block, which was considerably more!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
