i just got my 416 running so i dont really know horsepower but it seems to run strong , it is a 30 over 340 block with k-1 4 inch steel crank, k-1 rods , diamond dished pistons , comes in at 10.1 compression (thanks dram) the camshaft came from brian ou812 on the board . it is a 252 intake 260 exhaust at .050 ,with something like 597 intake lift and 614 exhaust, solid flat tap. the cylinder heads are from shady dell 360-1 stage one port job they are over kill on it, but i thought later i might grow into them. i would guess that i have some where around 3 grand in the short block.
heres some pics
t and d rockers
