Re: caltrac
[Re: Thumperdart]
#1714462
12/23/14 03:11 PM
12/23/14 03:11 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Yes, I talked to John Calvert, and the Mono-leaf would work better, but I will try the SS springs since I do drive the car on the street once in a while.
I've been running my split mono's with C-T Bars on the street for a few years now. No issues, don't know why there would be any; in fact, they work great because you can back the preload out of the bars and have a nice soft ride. The bars rely on the controlled flex of the split mono's, and transfer that flex into effective motion. I don't see where adding C-T bars to SS springs (which are just plain stiff) will have any effect. (??)
I can bend my ss like a twizzler[20* pinion up untell the u jount binds],what would a mono do?By the way Calvert told me if I liked my ride height/spring rate I did not need to go to a mono.
Fightin this all the way.............. Just look at the c-trac design and your q`s will be answered.
I was speaking in relation to spring rate that the ss is more in the front segment]I agree to how the C-T work.
