I found a guy here local to do it, who owns a welding business.... Will pick it up today and knock it out Monday
All goes well car should be running Tuesday. Norwalk is getting close, need to sort this thing out at the track probably twice before then. I expect some teething problems as a couple of things are probably marginal to support what I hope the car can run( mainly fuel related) won't know till I lean on it.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
