Quote: Doe's the intake sit on the china wall when bolted down? Is there a gap for a bead of silicone? Just thinking of anything to check!!!!
Thanks for trying to help! No there is a good .200" of gap from the bottom of the intake to the china walls. I have a great imprint of the head on the gasket, (torqued to 70in.lb. on center and 48 in.lb. on ends). But the oil is flowing past the gasket just the same!
