You're running spark plug gaskets, you can chuck those so they don't chew up the spark plug tubes. Inspect the spark plug tubes carefully to see if they are damaged and letting oil by. If you are not running Stage V heads I would suggest running Milidon tube seals as well, Stage V heads have O-rings machined in right from Stage V and don't need the extra tube seals.
