Re: Switch from 10-30 to 20-50 pressure change?
[Re: Hemi ragtop]
#1659132
08/15/14 12:59 AM
08/15/14 12:59 AM
Posts: 9,861 MI, usa
dvw
MI, usa
I have been fighting oil usage in a 2d gen HEMI for over 2,500 miles. The first suggestions were intake sealing. With the help of Proformance gaskets, I am confident that the intake is sealed. Still I have oil usage, (one quart in 100 miles). The funny thing is, my buddies don't see oil smoke while following me, the pipes and plugs are a light tan. While at the Nats, I talked to several "celebrity" engine builders and several HEMI owners. The consensus is: change from 10-30 to 20-50 oil. I have been using Brad Penn. One owner told me that 18 YEA,RS AGO he changed to 20-50 and has not had a usage problem since.
Does anyone have any input on a HEMI that is just driven? My engine is set up with "loose" clearances, forged pistons, Teflon seales etc.
If You're using a quart every 100 miles no oil in the world is going to help. If there are no external leaks it's burning in the cylinders. Intake to head,guides/seals,rings, hole in the intake port. 100 miles per qt is not a normal situation. Put some dye in the oil. Then I'd pull the intake and have a look. Lets see the plugs. Doug
