Re: New cam bearings, takes 24 ft lbs to turn cam.
[Re: Crizila]
#1610393
04/22/14 01:44 AM
04/22/14 01:44 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[ The second common way is to take a used cam and cut a groove across each cam journal and spin it in the bearings untill you have them clearanced.
diagonal groove(s). that'd be the way I would deal with this, & clean the shavings
Hey Robert . thats what I do. Took and old cam and cut diagonal grooves in the journals. A couple of passes throught the cam bearings and your good to go.
Yep, diagonal groove I didnt specify. It helps with the cut and the flow of the shavings for cleanup. It will take more then just a couple of passes though, in most cases.
Entire Thread
cougar_cat_25
04/22/14 01:27 AM
Dunnuck Racing
04/22/14 01:34 AM
69charger440_6pa
04/22/14 02:09 AM
Sport440
04/22/14 02:19 AM
RapidRobert
04/22/14 02:23 AM
Crizila
04/22/14 04:49 AM
Sport440
04/22/14 05:44 AM
RapidRobert
04/22/14 04:07 PM
moderncylinder
04/23/14 04:32 AM
Cab_Burge
04/22/14 02:50 AM
dvw
04/22/14 03:03 AM
n20mstr
04/22/14 03:14 AM
MR_P_BODY
04/22/14 03:20 AM
cougar_cat_25
04/22/14 03:29 AM
n20mstr
04/22/14 03:42 AM
383man
04/22/14 04:34 AM
Cab_Burge
04/22/14 08:31 AM
cougar_cat_25
04/22/14 04:02 PM
Clanton
04/23/14 12:25 PM
Dyno1
04/23/14 05:52 PM
Moparnut426
04/23/14 06:50 PM
John_Kunkel
04/23/14 07:45 PM
onig
04/29/14 05:08 AM
B G Racing
04/29/14 03:10 PM
tsanchez
04/29/14 08:57 PM
cougar_cat_25
04/29/14 02:26 AM
Cab_Burge
04/29/14 05:02 AM
Clanton
04/29/14 11:51 PM
MR_P_BODY
04/30/14 12:53 AM
Cab_Burge
04/30/14 01:44 AM
MNobody
04/30/14 04:53 AM
Clanton
04/30/14 02:25 AM
cougar_cat_25
05/30/14 12:15 AM
roadhazard
05/30/14 04:06 AM
