I keep an old cam around and smack on a 3/4 alum dowel thru the lifter holes to make the cam seat the cam bearing into the bore, sometimes when the bearing passes the holes it distorts, I hit them from both side at each bearing and from the crank area a few times and they spin up nice and clean without removing any material.
