Quote: Thanks for the info guys! I wish I kept the last two cams I wiped the lobes on to make a scraper out of. I did put the crank in so the broomstick idea sounds great.
When your done with the cam bearings remove the crank and main bearings and clean everything very thoroughly Engine assembly is like brain surgery, it is absolutely impossible to keep it to clean
