Re: Need advice, plugs fouled, backfiring thru carb
[Re: RMCHRGR]
#1595128
03/20/14 11:56 PM
03/20/14 11:56 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
OK, I guess I can say I made some progress since I got it running and 'idling'. Can't say where it was idling at, my tach is not hooked up but it was over 1,000 rpm for sure.
I did what Mr. P said with the timing and it seemed to help get it started. While it was running, it was @ 14 on the damper.
Got a new set of Champion RC9YCs because I didn't think they were fouling because of heat range.
So once it was running, I realized that it was REALLY lean, like piston melting lean. My A/F gauge was reading 13 and when I snapped the throttle it went to 15-16. Temp never got too high and I shut it off after a little while. I could feel it running hot.
In addition, I am still having a hard time getting it to start consistently though and when it doesn't fire, it fouls the plugs.
I went and got 3.5 PV. That was in it while it was running. I thought it might have been contributing to the lean condition so I put a 4.5 afterwards but I didn't get it running again due to plug fouling.
Seems like adjusting the throttle plates had the most affect on starting the car and getting it running. I was still popping a little but not as bad as the other day. Probably cause it's lean when running?
Man, I am lost with this, shouldn't be this hard. Hope you guys can provide a little more guidance.
Here's a pic of the plug after it ran.
'71 Duster '72 Challenger '17 Ram 1500
Entire Thread
Need advice, plugs fouled, backfiring thru carb UPDATE
RMCHRGR
03/19/14 04:10 AM
MR_P_BODY
03/19/14 04:49 AM
RMCHRGR
03/19/14 05:04 AM
MR_P_BODY
03/19/14 05:12 AM
RMCHRGR
03/19/14 07:57 PM
camastomcat
03/19/14 08:11 PM
roadhazard
03/19/14 08:39 PM
GTX MATT
03/19/14 09:37 PM
RMCHRGR
03/20/14 04:40 AM
RMCHRGR
03/21/14 03:56 AM
RMCHRGR
03/29/14 03:13 AM
MR_P_BODY
03/29/14 03:34 AM
RMCHRGR
03/29/14 03:51 AM
MR_P_BODY
03/29/14 04:02 AM
RMCHRGR
03/29/14 04:25 AM
MR_P_BODY
03/29/14 04:52 AM
B G Racing
03/29/14 12:30 PM
Chris'sBarracuda
03/29/14 01:23 PM
RMCHRGR
03/29/14 04:21 PM
Shoozy
03/29/14 04:24 PM
MR_P_BODY
03/29/14 04:25 PM
RMCHRGR
03/29/14 05:10 PM
DodgeCharger
03/29/14 05:56 PM
RobX4406
03/29/14 06:50 PM
RMCHRGR
03/30/14 12:07 AM
MR_P_BODY
03/30/14 01:22 AM
RMCHRGR
03/30/14 03:01 AM
sunroofgtx
04/02/14 08:30 PM
racingblues1426
04/02/14 08:48 PM
B G Racing
04/02/14 09:02 PM
RMCHRGR
04/03/14 04:02 AM
RMCHRGR
04/21/14 08:56 PM
joedust451
04/21/14 11:18 PM
RMCHRGR
04/22/14 02:40 AM
Cab_Burge
04/22/14 03:25 AM
B G Racing
04/22/14 08:52 PM
RMCHRGR
04/23/14 12:26 AM
B G Racing
04/23/14 08:40 PM
DodgeCharger
03/29/14 03:20 PM
