Not sure if I am understanding things right here, but if you are saying the slave isn't stroking, maybe the master is bypassing, internal leak?
What does the inside of the firewall look like?
I had a '93 Jeep Wrangler, same symptoms (I think) clutch master was leaking at the firewall, and not releasing the clutch.
there was no evidence of leakage, pulled the slave and yes it stroked, once. Lost pedal, then I messed the hose up while shoving the rod back into the slave cyl causing it to leak at the angled fitting on the hose end of the slave.
