careful doing that...the slave on my Dakota seems to have a spring in it that keeps it extended snug up against the fork. must be to keep it engaged with the fork so it doesn't fall off? when not installed and hanging free, it would fully extend by itself, and then if you stroke the clutch pedal, it would push the cup and pushrod out the end of the slave.
**Photobucket sucks**
