more progress on the Narrowed Rear install. Installing the shackle bushings at the rear leaf spring eye's had me wanting to give up! The eyelet is too small to fit the rubber bushing in and the shackle shaft. work the bushing in and then try to press the shackle shaft in. IT DOES'NT FIT! Called my brother "Model Maker" and he said why don't you just mill them down a little? ......Hey, that's exactly what I was thinking
