The rear shackle tubes burned in and moving on to the narrowed diff assembly. I need to mock up the spring pad placement and set the installed pinion angle. I need to find out what pinion angle is best for my set-up. Should I try for the stock degree angle or maybe a little down from stock angle? I'm installing new Mopar SuperStock springs from Mancini Racing.
