Quote: now that shes back on all four wheels i'm moving on to the subframe connectors, moving the springs inboard with a set of superstocks and mini tub'in it. All that needs to be completed before i can have a exhaust system custom fit.
i do have one dilemma with the cooling system i am juggling with. I would rather run a 26" brass/copper 3 row radiator with a fan clutch and shroud than a Aluminum set-up with electric fans. I'm looking at a Spectra CU332. Haden 2765 fan clutch. Am i heading down a dead end road?
Will it fit? Will it cool? Fan shroud unavailable? looks hoakie?
I guess the question has been answered! Short of rad hoses and installing the correct 18" fan I think this should work just fine I don't think cooling should be an issue.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
