You might want to run the engine now and see if there is any vibration there. The more things eliminated the less you have to think about.
Not gonna be able to use a starter now.
Unless you have nuetral balanced stick flywheel and bellhousing to match the size of the flywheel I do OP, I hope you find the problem Let us know what you do find
