Man that had to make a ton of noise from the looks of it.Oh and to the people that say you cant put a flex on backwards.Guess again.Had a guy at the shop that did on the Mittsy 2.6.He didnt think anything was wrong with all the bolts not lining up.But he put it in and had the motor all bolted together.It was a lot of work but he did it.After all these years I still wonder how.Rocky
You cannot do it on a big or small block. Bolt hols are offset on both the crank and the converter.
