I am not trying to change your mind here but this "electric fans won't cool enough" is bogus. If that was the case, then modern day cars would still be running mechanical fans.
The use of electric fans in modern vehicles has nothing to do with cooling. If you wish to use an example to support your position make sure it's relevant.
A PROPERLY setup electric fan does work, but it is substantially more expensive and complicated than a mechanical fan, all to do the same job.
KISS
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
