what year do you use? and what did you do to the valve body? is it a manual valve body? thanks
Its a early 90s trans... mine is a 3 pin connector
or you can use a single pin connector... do not use
the 7 pin unit.. that requires the computer to control
the trans.. mine is just a regular valve body so it
shifts like a normal trans... but the OD can be left
on in any gear... but its advised to not put a lot
of power to the OD unit... its just a clutch that
engages it with a 900# spring pressure
Just to clarify, what exactly so you mean the OD can be left on in any gear? Do you mean you can just leave it on and it works normally or is the OD engaged along with whatever gear it's in(example 1st + OD)?
