what year do you use? and what did you do to the valve body? is it a manual valve body? thanks
Its a early 90s trans... mine is a 3 pin connector
or you can use a single pin connector... do not use
the 7 pin unit.. that requires the computer to control
the trans.. mine is just a regular valve body so it
shifts like a normal trans... but the OD can be left
on in any gear... but its advised to not put a lot
of power to the OD unit... its just a clutch that
So how is the OD activated?? I would think you'd only want it applied in the high (1:1) gear...
engages it with a 900# spring pressure
