anyone using 518 o/d for street and track/what eng and what hp level do you have? what did you do about t/conv, l/up or non l/u? how is it holding up? if bb, what did u use for bellhousing? thanks in advance.
I'm running a 518 in the Rampage... I changed the input
shaft and pump to use a standard hi stall conv.. I
dont have lock up that way... its behind a 550 hp 418ci...
love the OD... cuts the revs down nicely with 4.10
gears
Mike, Did you just use a 727 pump and input shaft? Beep
I believe its a 727 pump and input... I got it from Cope
