I've lowered my nose down some to help the look out and noticed that the lower control arm bump stops, are right about on the frame. Which is a bummer due to I have the right look.
What side effects could I expect if I shaved some off of the rubber stops?
Thanks!
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
