I've lowered my nose down some to help the look out and noticed that the lower control arm bump stops, are right about on the frame. Which is a bummer due to I have the right look.
What side effects could I expect if I shaved some off of the rubber stops?
Thanks!
Mine is pretty low also, do you have any pics. How much clearance do you have?
About an 1 1/2" to 1 1 5/8" with NO bumpstops.
That thing is low! Looked at my car, it's fairly close as well..may have to do the same with the stops. Any lower and I think my 255s would kiss the lip of the fenders with a hard turn
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
