Energy and Prothane make some very short bump stops that will bolt in. Sounds like you might have some tall tires in the front?
do you have a link or part number for those? Sounds like what i need! I assume there is just a nut I can access through the lca to remove the stop, correct?
26" tall tires on the front.
Drop spindles is the best way to go, but hard to find for some cars. On my 72 Challenger, I cut the factory bump stop in half and set the arm a 1/2 inch away. It looked real good a drove just fine after the shop reset the front end.
Snap your neck, mega G-force launch, is all I want!
