Energy and Prothane make some very short bump stops that will bolt in. Sounds like you might have some tall tires in the front?
do you have a link or part number for those? Sounds like what i need! I assume there is just a nut I can access through the lca to remove the stop, correct?
26" tall tires on the front.
That's not that tall of a tire.
Bump stops: http://www.streetperformance.com/part/energy-suspension/bump-stops/493178-9-9102g.html
Those ones come up as for a buick rivera, have you used these on a mopar sucessfully?
It will fit with 2" diameter. The lower contol arm just have a hole in the lower for the factory bushing. The poly doesnt have a square on the bolt, so you will have to hold the poly portion when you tighten it.
Might have a grind a little of the diameter is over 2 1/4" it might conflict with the flange on the LCA.
