Re: Lowered front end - Ebody - On bump stops
[Re: Mopar72Man]
#141438
10/26/08 09:08 AM
10/26/08 09:08 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Energy and Prothane make some very short bump stops that will bolt in. Sounds like you might have some tall tires in the front?
do you have a link or part number for those? Sounds like what i need! I assume there is just a nut I can access through the lca to remove the stop, correct?
26" tall tires on the front.
That's not that tall of a tire.
Bump stops: http://www.streetperformance.com/part/energy-suspension/bump-stops/493178-9-9102g.html
[Re: Mopar72Man]
#141441
10/26/08 11:40 AM
10/26/08 11:40 AM
Posts: 4,745 Florida
BDW
I've lowered my nose down some to help the look out and noticed that the lower control arm bump stops, are right about on the frame. Which is a bummer due to I have the right look.
What side effects could I expect if I shaved some off of the rubber stops?
Thanks!
Mine is pretty low also, do you have any pics. How much clearance do you have?
[Re: Mopar72Man]
#141442
10/26/08 03:49 PM
10/26/08 03:49 PM
autoxcuda
So Cal
Those ones come up as for a buick rivera, have you used these on a mopar sucessfully?
It will fit with 2" diameter. The lower contol arm just have a hole in the lower for the factory bushing. The poly doesnt have a square on the bolt, so you will have to hold the poly portion when you tighten it.
Might have a grind a little of the diameter is over 2 1/4" it might conflict with the flange on the LCA.
[Re: BDW]
#141443
10/26/08 04:04 PM
10/26/08 04:04 PM
autoxcuda
So Cal
Thanks!
About an 1 1/2" to 1 1 5/8" with NO bumpstops.
[Re: autoxcuda]
#141444
10/26/08 04:10 PM
10/26/08 04:10 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks!
That thing is low! Looked at my car, it's fairly close as well..may have to do the same with the stops. Any lower and I think my 255s would kiss the lip of the fenders with a hard turn
[Re: GoodysGotaCuda]
#141445
10/26/08 04:19 PM
10/26/08 04:19 PM
autoxcuda
So Cal
Ain't no thang.
I've ran into a mountain with it once.... Seriously.... went off course at Willow Springs and bent the valence, front bottom fender, and scraped the bottom of the bumper.
I should put something in there. Maybe slide in an old hard stick of Wrigley's spearment.
[Re: AlexP]
#141447
10/26/08 04:29 PM
10/26/08 04:29 PM
autoxcuda
So Cal
I'm as low as it can go. I've got the short poly bumpstops too.
At that height and those tall tires I think you should consider notching the frame. You've got to be much closer from the LCA to frame the I am.
I've got pics of a notched frame on a 70 Cuda. I helped the same guy do it to a 68 RR.
The distance from the LCA to the frame is a function of the body/frame height AND the front tire diameter.
