Lowered front end - Ebody - On bump stops #141433
10/25/08 08:26 PM
10/25/08 08:26 PM
Oklahoma
Mopar72Man Offline OP
Oklahoma
I've lowered my nose down some to help the look out and noticed that the lower control arm bump stops, are right about on the frame. Which is a bummer due to I have the right look.
What side effects could I expect if I shaved some off of the rubber stops?
Thanks!
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: Lowered front end - Ebody - On bump stops [Re: Mopar72Man] #141434
10/25/08 08:37 PM
10/25/08 08:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
First thing that happens is that there's no suspension travel on bumps; they'll tend to steer the car. Not good when cornering and you encounter bumps. Too low and the camber goes real negative. On nice roads, an inch of travel at the bump-stop area would be about minimum; that makes for more travel out where the tires are, but still not much.
A better way to accomplish the lowering would be with drop spindles.
As far as negative camber, I've run as much as -2 degrees with no problems, but that's a cornering setup; in a straight line it'll wear out the inner portion of the tread quicker.
Re: Lowered front end - Ebody - On bump stops [Re: topside] #141435
10/25/08 08:42 PM
10/25/08 08:42 PM
Oklahoma
Oklahoma
thanks, actually I haven't really had any complaints for the ride. It didn't seem like it was bottomed out, thats for sure. I do have firmer shocks up front, so chopping some off the stop shouldn't be too bad of an option. I would not like to lower it anymore than it is since it rides pretty true with no tire wear concerns.
Re: Lowered front end - Ebody - On bump stops [Re: Mopar72Man] #141436
10/25/08 10:32 PM
10/25/08 10:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Energy and Prothane make some very short bump stops that will bolt in. Sounds like you might have some tall tires in the front?
Re: Lowered front end - Ebody - On bump stops [Re: autoxcuda] #141437
10/26/08 08:51 AM
10/26/08 08:51 AM
Oklahoma
Oklahoma
do you have a link or part number for those? Sounds like what i need! I assume there is just a nut I can access through the lca to remove the stop, correct?
26" tall tires on the front.
Re: Lowered front end - Ebody - On bump stops [Re: Mopar72Man] #141438
10/26/08 09:08 AM
10/26/08 09:08 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That's not that tall of a tire.
Bump stops: http://www.streetperformance.com/part/energy-suspension/bump-stops/493178-9-9102g.html
Re: Lowered front end - Ebody - On bump stops [Re: Mopar72Man] #141439
10/26/08 09:10 AM
10/26/08 09:10 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Drop spindles is the best way to go, but hard
to find for some cars.
On my 72 Challenger, I cut the factory bump stop
in half and set the arm a 1/2 inch away.
It looked real good a drove just fine after
the shop reset the front end.
Snap your neck, mega G-force launch, is all I want!
Re: Lowered front end - Ebody - On bump stops [Re: autoxcuda] #141440
10/26/08 10:33 AM
10/26/08 10:33 AM
Oklahoma
Oklahoma
Those ones come up as for a buick rivera, have you used these on a mopar sucessfully?
Re: Lowered front end - Ebody - On bump stops [Re: Mopar72Man] #141441
10/26/08 11:40 AM
10/26/08 11:40 AM
BDW Offline
BDW  Offline
Thanks!
Mine is pretty low also, do you have any pics. How much clearance do you have?
Re: Lowered front end - Ebody - On bump stops [Re: Mopar72Man] #141442
10/26/08 03:49 PM
10/26/08 03:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It will fit with 2" diameter. The lower contol arm just have a hole in the lower for the factory bushing. The poly doesnt have a square on the bolt, so you will have to hold the poly portion when you tighten it.
Might have a grind a little of the diameter is over 2 1/4" it might conflict with the flange on the LCA.
Re: Lowered front end - Ebody - On bump stops [Re: BDW] #141443
10/26/08 04:04 PM
10/26/08 04:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks!
About an 1 1/2" to 1 1 5/8" with NO bumpstops.
Re: Lowered front end - Ebody - On bump stops [Re: autoxcuda] #141444
10/26/08 04:10 PM
10/26/08 04:10 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks!
That thing is low! Looked at my car, it's fairly close as well..may have to do the same with the stops. Any lower and I think my 255s would kiss the lip of the fenders with a hard turn
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Lowered front end - Ebody - On bump stops [Re: GoodysGotaCuda] #141445
10/26/08 04:19 PM
10/26/08 04:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Ain't no thang.
I've ran into a mountain with it once.... Seriously.... went off course at Willow Springs and bent the valence, front bottom fender, and scraped the bottom of the bumper.
I should put something in there. Maybe slide in an old hard stick of Wrigley's spearment.
Re: Lowered front end - Ebody - On bump stops [Re: GoodysGotaCuda] #141446
10/26/08 04:21 PM
10/26/08 04:21 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I'm as low as it can go. I've got the short poly bumpstops too.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Lowered front end - Ebody - On bump stops [Re: AlexP] #141447
10/26/08 04:29 PM
10/26/08 04:29 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
At that height and those tall tires I think you should consider notching the frame. You've got to be much closer from the LCA to frame the I am.
I've got pics of a notched frame on a 70 Cuda. I helped the same guy do it to a 68 RR.
The distance from the LCA to the frame is a function of the body/frame height AND the front tire diameter.
