Quote: If you would look 440 source does use and have alot of parts pistons rods, rod bolts intakes that are made right here in the USA! go check it out ! before blasting!! just as any crank co some made here other made out side the USA !! http://store.440source.com/MADE-IN-USA/products/121/
It's Chinese steel dude. Where its machined doesn't make it US made. Cranks, rods, cheap for a reason.
Tell me friend, what brand are your crank and rods?
